Amd Ph2+gtx285 or Intel9550+gtx280??
484 Views 11 Replies 5 Participants Last post by  gerikoh
im on a really tight budget and im making a pc on newegg and i have 2 choices.
the amd phenom 2 940 @ 3.0ghz +gtx 285 @675mhz OR
the intel quad 9550 @2.83+gtx 280 @602mhz..
im keeping these cpu's at stock. since i have no idea how to overclock.
which one would be better only for gaming?
1 - 12 of 12 Posts
who says after you build this pc you won't want to learn to overclock?
and to be honest.....I am pretty sure that comparison is quite close. I think what decides this one is if your an amd or intel guy....
AMD but are you absolutely set on the GTX 280 or GTX 285?
yes i cant change it
thats basically what it is .
Well make sure you find yourself an nVidia board then if you want to run SLI with those cards.
no sli.. i prefer the best single card solution. or upgrade to a 295 in the future.
Have you picked a board?
if i go with intel 9550 this one:
http://www.newegg.com/Product/Produc...82E16813128372
amd this one:
Edit: oops amd this one:
http://www.newegg.com/Product/Produc...82E16813138130
Those are both the same boards.
check now i edited sorry X/
the cpus are similar in terms of performance. it's the gpu that will make the difference in gaming.
so the amd build will be a smarter choice.
and since you won't sli, this is the cheapest good overclocking mobo, with the best amd chipset out there:
http://www.newegg.com/Product/Produc...82E16813138140
1 - 12 of 12 Posts
