AMD Phenom II X3 720 Compatibility
794 Views 5 Replies 3 Participants Last post by  gerikoh
Hey guys,
I wanted to check with you to make sure that this processor:
http://www.newegg.com/Product/Produc...82E16819103649
is compatible with this motherboard:
http://www.newegg.com/Product/Produc...82E16813131330
About to put a system together with these two components and just wanted to make sure they fit
Thanks!
Skillz
1 - 6 of 6 Posts
yep. update it with the 1201 bios
Yeah they will work fine. But if you plan on oc'ing I would get the 790gx chipset which can be had for only slightly more 10 maybe 20 bucks
I'm not going to have to flash the bios to get the processor to work, right? I don't have another AMD laying around here to use to flash the mobo...
I think it will be ok.. you could dl the newest bios on your current pc get the flasher utility setup on a flash drive and then install the new bios on first boot.. Might work..
you need to. otherwise, get an am3 ready mobo like this one:
http://www.newegg.com/Product/Produc...82E16813186165
1 - 6 of 6 Posts
