AMD Phenom II X4 955 + ASUS M4A77TD ?
4198 Views 10 Replies 4 Participants Last post by  AvgWhiteGuy
Guys i need ur help here, i just wonder if http://www.newegg.com/Product/Produc...82E16813131397
and
http://www.newegg.com/Product/Produc...82E16819103674
With GTX 260 Nvidia + Memory 1066 would work fine?
i m thining about Buying Board and CPU but i really Dont know if they WOuld work good with My Video Card and my Memory plz reply Asap. Thanks
1 - 11 of 11 Posts
That board only supports DDR3 ram . You would need to upgrade the ram as well
Edit Unless thats DDR3 1066 in that case it will work
Well i guess i m ****ed then cuz i cant spend more money on memory, any ways thanks for the help
I think some of these boards support DDR2 and AM3
http://www.newegg.com/Product/Produc...2fAM2%2b%2fAM2
http://www.newegg.com/Product/Produc...82E16813128395 would work fine with my 260 GTX and that AM3?
Looks like it
edit: checked the CPU support list the 955 is on there and DDR2 1066 ram and it's a decent overclocker
Looks like it
Thanks man, and sorry for being a noob :/
No problem.
Also you might want to fill in your system specs with what you have now so members can help you out.
http://www.overclock.net/specs.php?do=addsystem
No problem.
i will, Thanks.
Originally Posted by flashdr View Post
i will, thanks.
no mate you are all gone wronge.
Give it up and get your self a type wrighter lol
Good to see you brougt something of value to this thread, I know I'm trolling and I'm not bringing anything either but wanted to point it out.
1 - 11 of 11 Posts
