well today i was running nfs 2 demo
and after 3 mintues computer crash.
booted back in game same thing happend.
i knew it wasn't video card.
so i went and i changed my memory settings and cpu setting to defualt and everything is okay.
now i wanna know which one it is.
cpu was at 2100 so overclocked 100mhz with venus 12 max load is 50C.
memory is not OC but timing had been 2.5 3 3 8.
now this ram is kingmax 466.
where u guys think the problem is?
i have asus k8n-e with amd 64 3000+ ati 9800 pro 1 gb of ram.
i recently updated the bios and for some reason i can't go above 2.1ghz
and one other thing is that mem is at 2.5 4 4 8.
and anytime i tried to make it less than 2.5 which is 2 i have to remove the batt
maybe your memory just cant take a 2.5 Cas Latency. Which is fully possible. As far as the BIOS and not being able to go over 2.1ghz search me, thats a new one.
well Games, despite not requireing as much stability as benchmarks, still requre a lot of stability so if any one of your components is having issues with a setting in your BIOS you may not notice it until you start playing the game when the instability becomes an issue the game will hang. So it is sort of a hard thing to narrow down which one it is because it could be either or, or maybe even both. All it takes is one component not liking a setting to make the entire computer less than 100% stable.
which ram u mean the kinmax 466?
i will tyr to go over the volatge by 1 or 2
i just dono
before i used to go for 2.4 np
now after this bios thing i can't
And make sure your heat sink is seating correctly!!! You are a bit warm there considering the FHS you are using, unless you case circulation is very poor!
BIOS updates are best only when needed or that the one you have has a known quirk. If it ain't fixed dont hit it with a hammer
Heck, I'm thinking bout flashing back 7 versions LMAO because the 1.04 ver (my board not yours, allows CPU voltage over 2v HOT DAM
BTW, how much mem do you have allocated tp your AGP aperature? You don't need any more than 512megs total vid overall. (Vid card RAM + AGP Aperature allocation = 512 total) =
Overclock.net
