1 - 10 of 10 Posts
Fan Man
Download Page (amd.com)
Release Notes (amd.com)
Support For
  • Sea of Thieves™
    • Up to 29% faster performance using Radeon Software Adrenalin Edition 18.2.3 on the Radeon™ RX Vega 64 (8GB) graphics card than with Radeon Software Adrenalin Edition 18.2.2 at 3840x2160. RS-215
    • Up to 39% faster performance using Radeon Software Adrenalin Edition 18.2.3 on the Radeon™ RX 580 (8GB) graphics card than with Radeon Software Adrenalin Edition 18.2.2 at 1920x1080. RS-216
  • Brass Tactics™
  • Final Fantasy® XII The Zodiac Age
    • Up to 13% faster performance using Radeon Software Adrenalin Edition 18.2.3 on the Radeon™ RX Vega 56 (8GB) graphics card than with Radeon Software Adrenalin Edition 18.2.2 at 2560x1440. RS-212
    • Up to 20% faster performance using Radeon Software Adrenalin Edition 18.2.3 on the Radeon™ RX 580 (8GB) graphics card than with Radeon Software Adrenalin Edition 18.2.2 at 2560x1440p. RS-213
Fixed Issues
  • Radeon FreeSync may intermittently incorrectly engage during Chrome video playback resulting in playback flicker.
  • Radeon FreeSync may rapidly change between min and max range when enabled causing stutter in fullscreen games on multi display system configurations.
  • Flickering may be observed on the performance metrics overlay when Enhanced Sync is enabled on some Radeon FreeSync connected displays.
  • Radeon Overlay may exhibit minor flickering when enabled while playing games using the Vulkan™ API.
  • Fortnite™ may experience lighting or fog corruption on some graphics quality presets.
  • Radeon ReLive instant replay clips may intermittently contain small amounts of audio distortion.
  • Middle-earth™: Shadow of War™ may experience an application crash when launched as a Universal Windows® Application.
  • For Honor™ may experience an intermittent application crash on launch.
Known Issues
  • A random system hang may be experienced after extended periods of use on system configurations using 12 GPU's for compute workloads.
  • Water textures may appear to be missing in World of Final Fantasy™.
  • Destiny 2™ may experience an application hang in the mission "Heist" on some Radeon GCN1.0 products.
  • Radeon Overlay may intermittently fail to enable when toggled in some games.
  • Radeon Chill hotkey may fail to reset when Radeon Settings is restored to defaults.
  • FFmpeg application may experience corrupted output for H264 video streams.
Footnotes
  • Testing conducted by AMD Performance Labs as of February 21st, 2018 on the 8GB Radeon RX Vega 56, on a test system comprising of Intel i7 7700X CPU (4.2 GHz), 16GB DDR4-3000 Mhz system memory, and Windows 10 x64. PC manufacturers may vary configurations, yielding different results. With Ultra settings on Final Fantasy XII: The Zodiac Age , at 2560x1440, the Radeon RX Vega 56 scored 57.6 FPS with Radeon Software 18.2.3 whereas the Radeon RX Vega 56 scored 51 FPS with Radeon Software 18.2.2. Comparing FPS between software versions, Radeon Software 18.2.3 has 13% faster performance in Final Fantasy XII: The Zodiac Age. Performance may vary based on use of latest drivers. RS-212
  • Testing conducted by AMD Performance Labs as of February 21st, 2018 on the 8GB Radeon RX 580, on a test system comprising of Intel i7 7700X CPU (4.2 GHz), 16GB DDR4-3000 Mhz system memory, and Windows 10 x64. PC manufacturers may vary configurations, yielding different results. With Ultra settings on Final Fantasy XII: The Zodiac Age , at 2560x1440, the Radeon RX 580 scored 43.5 FPS with Radeon Software 18.2.3 whereas the Radeon RX 580 scored 36.1 FPS with Radeon Software 18.2.2. Comparing FPS between software versions, Radeon Software 18.2.3 has 20% faster performance in Final Fantasy XII: The Zodiac Age. Performance may vary based on use of latest drivers. RS-213
  • Testing conducted by AMD Performance Labs as of February 22nd, 2018 on the 8GB Radeon RX Vega 64, on a test system comprising of Intel i9 7900X CPU (3.3GHz), 32GB DDR4-3000 Mhz system memory, and Windows 10 x64. PC manufacturers may vary configurations, yielding different results. With Ultra settings on Sea of Thieves at 3840x2160, the Radeon RX Vega 64 scored 51.767 FPS with Radeon Software 18.2.3 whereas the Radeon RX Vega 64 scored 40.174 FPS with Radeon Software 18.2.2. Comparing FPS between software versions, Radeon Software 18.2.3 has 29% faster performance in Sea of Thieves. Performance may vary based on use of latest drivers. RS-215
  • Testing conducted by AMD Performance Labs as of February 22nd, 2018 on the 8GB Radeon RX 580, on a test system comprising of Ryzen 1700 CPU (3.4GHz), 32GB DDR4-3000 Mhz system memory, and Windows 10 x64. PC manufacturers may vary configurations, yielding different results. With Ultra settings on Sea of Thieves at 1920x1080, the Radeon RX 580 scored 70.55 FPS with Radeon Software 18.2.3 whereas the Radeon RX 580 scored 50.9 FPS with Radeon Software 18.2.2. Comparing FPS between software versions, Radeon Software 18.2.3 has 39% faster performance in Sea of Thieves. Performance may vary based on use of latest drivers. RS-216
Package Contents
The Radeon Software Adrenalin Edition 18.2.3 installation package contains the following:
  • Radeon Software Adrenalin Edition 18.2.3 Driver Version 17.50.25.01 (Windows Driver Store Version 23.20.15025.1004).
The Challenger
Fixed Issues
Oh this is great. That Chrome playback flicker annoyed me to hell and back. I resorted to turning off FreeSync whenever I even think of browsing, and turning it back on before gaming. It was quite the nuisance. Glad to see it is fixed.
Audio issues with Instant Replay has been an annoyance since the beginning. I'll have to test this out.
I've experienced many crashes while starting For Honor. It generally required me to re-install the game before each play session.
This might be the most relevant driver update in quite a while, at least for me. I have to install this ASAP.
Has an issue switching between compute and graphics mode it seems.
Oh I hope not... I've been constantly switching between them. I'm constantly mining, except when I'm gaming, which is quite regularly.
My wife's system flickers constantly on the desktop when any kind of overclock is applied. No overclock it doesn't happen at all. This is using Afterburner or the Radeon Overdrive to overclock. Win10 and an HD7950.
Fixer
This driver is extremely unstable on my system. Intermittent lockups in Heroes of the Storm. When it does run there is intermittent flickering. Radeon settings crashes a lot. Any overclock makes everything worse. Rollback to 18.2.2 and no issues.
working good on my one 7950 system
Guess I'll update my driver and see if my HD7950 does that. Course my card sucks for core clocking ever since I RMA the thing for a fan....1150 core to now barely a 5mhz bump.
Mmmm donuts.....
I'm having no issues with mine, i did reset one of my game profiles and radeon crashed but that's happened on crimson as well. The one issue i have that's still not fixed is that in individual game profiles if i disable frtc it will not disable and gets stuck to global frtc. Fix is to set the limit to 300fps but it's not a fix. I'm using a freesync screen so I'm going to use RTCC instead.
Sunday League Jibber
So far so good. I didn't bother to DDU, either. Just Express Upgrade from within the Radeon menu.
Mmmm donuts.....
I usually uninstall with amd cleanup utility then registry clean with ccleaner, restart and reinstall, have had zero issues.
1 - 10 of 10 Posts
