1 - 13 of 13 Posts
Can AMD cards be used for, like, video or graphics rendering? Outside games, I mean. CUDA on NVIDIA cards can be used for rendering, right? Does AMD have something similar?
The Computer Guy
I can Render with my cards just fine.
What can you render?
The Computer Guy
I have render game car files from NR2003.
AMD cards have OpenCL and some rendering softwares support that. so you would need to check if a render software can use CUDA or OpenCL.
As far as I know there are very few renderers that use GPU.
Gelato is the only one I can even think of, and that's nvidia only.
Do you have an example of what uses OpenCL? I only know mining
The Computer Guy
This one here is free,Saw it in a post earlier:http://www.studiogpu.com/
AMD/ATI also has Stream which is equivalent to CUDA for nVidia.
Originally Posted by kromar;14261183
hm never heard of that, i thought OpenCL was the equivalent:eek:
CUDA has more supported apps, but STREAM is out there.
so that stream technology can also be used for rendering? and why would they use OpenCL and stream? seems a bit overkill to develop 2 times the same thing
can it be that they switched to OpenCL from this stream thing? in the wiki is something mentioned :
AMD has decided to support OpenCL (and DirectX 11) instead of the now deprecated Close to Metal in its Stream framework.[7]
http://en.wikipedia.org/wiki/OpenCL
i dont completely understand that sentence, did they swich?
1 - 13 of 13 Posts
