1 - 20 of 29 Posts
Ok I am new to this whole overclocking buisines (I am only use to building computers not overclocking processors). So I was wondering if someone could help me with some programs to use, what is safe for a sempron 3100 (only with a fan and heatsink I dont feel like spending any more $$).
Thanks Ryan
Welcome to overclock. First please fill out your profile. There is no good overclocking software to speack of. It should be done through the Bios
Thanks Ryan
Hm wait so your not overclocking and you want to know what programs it will run? If so it will run any program lol. May not be the fastest in some at stock though.
Discussion Starter #4
no no no I mean are there programs that will change the voltage to the processor or something like that?
And yes I would like to overclock my processor some
oh yeh I will be filling out my profile
Oh allright. Well fill out your profile. You should be able to hit 2.3 ghz at least with 1.4 vcore (stock) with decent temperatures.
Okay, your cpu is a Socket A. When your computer first starts up, you want to immediately access the bios menu. For my Abit NF7s 2.0 I hit the "delete" key about 5 seconds after powering on the computer, or restarting. From the bios menu, you can change your frequency and multiplier in combinations to oc (overclock). For instance, my cpu runs oem at a frequency of 200 megahertz with a multiplier of 11. 11 x 200 = 2.2ghz. Now if i change my multiplier to 12, then my cpu is running now at 2.4ghz. You can also change the frequency from your bios. It helps if you have good memory sticks, and increase the voltage on you memory sticks, which also may be accessed froom your bios menu.
Help this little bit of info helps you out a little bit.
WEll,Start with the CPU change Htt to 3x, Then start with the FBS, After you find the limit of the CPU then start on the memory. If you don't have good memory you will have to run a divider. Put it at 166 or 333. I'm not sure how it will read in your bios
Before one moves into such questions it is far better (I think) to find out the full system specificiations.
Please post your motherboard make and model. "Dunno" just does not cut it. If you want help then give the required information. Open your case and look for the silkscreened make and model.
R
Discussion Starter #14
ok one sec
MB,MSI MS-7142 K8MMV 754 here is the name so what should I do with it or look for?
Here are the specs on it.
MSI K8MM-V (MS-7142-010) Socket 754 ATX Motherboard, Dual DDR400, AGP8X, SATA RAID, VGA & LAN, 6ch Audio
MSI K8MM-V based on VIA K8M800-CE chipset supports Socket 754 AMD 64 / AMD Sempron CPU. VGA, LAN, maximum 2GB dual channel memory. MSI K8MM-V definitely a value gamer motherboard. MSI Part No: MS-7142-010.
Features: 9.44 in.(L) x 7.68 in.(W); Micro- ATX, 2 DIMMs w/ DDR 400 upto 2 GB, 1 AGP 8X; 3 PCI; 8 USB, 6 Ch. Audio; 10/100 LAN; RAID; SATA; ATA133, S3 Graphics UniChrome 2D/3D Graphics with motion compensation assign upto 64MB of video Memory, Live Update; Fuzzy Logic; PC Alert.
Specifications: CPU: Supports 64-bit AMD Athlon 64 processor (Socket 754), Supports 2800+, 3000+, 3200+, 3400+, 3700+, Supports Sempron 2600+, 2800+, 3000+, 3100+, 3300+. Chipset: VIA K8M800-CE Chipset: HyperTransport connection to AMD Next Generation of CPU, 8 or 16 bit control/ address. data transfer both directions, 800/600/400/200MHz "Double Data Rate" operation both direction, AGP v3.0 compliant with 8X transfer mode, On-board Graphic shared up to 64MB. VIA VT8237R Chipset: Ultra DMA 66/100/133 master mode EIDE controller, Integrated dual channel native Serial ATA/RAID controller that will supply 150MB/s and support RAID 0, RAID 1, ACPI & PC2001 compliant enhanced power management, Supports 8 USB2.0 ports. (Rear x4/ Front x4). Main Memory: Supports two 184-pin DDR SDRAMs up to 2GB memory size, Supports DDR400/DDR333/DDR266 DDR SDRAM, Slots: One AGP (Accelerated Graphics Port) 1.5V 4x/8x slot, Three PCI 32-bit Master PCI Bus slots. (support 3.3v / 5v PCI bus interface). BIOS: The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and expansion cards of the board automatically. The mainboard provides a Desktop Management Interface (DMI) function which records your mainboard specifications. On-Board IDE: An IDE controller on the VT8237R chipset provides IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA 66/100/133 operation modes. It can connect 4 Ultra ATA drives. Serial ATA/150 controller integrated in VT8237R: Up to 150MB/s transfer speed, Can connect up to 2 Serial ATA drives, Support RAID 0, RAID 1. Audio: 6 Channel software audio codec VIA VT1617A, Compliance with AC97' v2.3 Spec, Meet PC2001 audio performance requirement. LAN: VIA VT6103L 10/100 Mb/s PHY, Supports 10/100 Mb/s auto-negotiation operation, Compliant with PCI v2.2 and PC99 standard, Compliance with ACPI Power Management. On-Board Peripherals: 1 floppy port supports 1 FDD with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes, 1 serial ports COM1, 1 VGA port, 1 parallel port supports SPP/EPP/ECP mode, 8 USB 2.0 ports (Rear x 4 / Front x 4), 3 audio ports in vertical (Line-out, Line-in, MIC), 1 RJ-45 jack, 1 IrDA connector for SIR/ASKIR/HPSIR. Dimension: 9.44in.(L) x 7.68in.(W) Micro-ATX Form Factor. Mounting: 6 mounting holes.
PCB Color: Red.
Oh yeh and ps: I always have my comp open (keeps it cool during gaming and benchmarking)
My RAM is Hynix
Pc32009-30330
512mb DDR 400 Mhz
Processor AMD sempron 3100+ 1.8 ghz
The download of your motherboard manual.
http://www.msi.com.tw/program/suppor...UID=647&kind=1
The newest bios download for your mainboard.
This manual gives no view of the bios readings so I can not give you them.
What I would look for is a pci/agp lock. Should look like 33/66 in the settings.
Then I would set the HTT Multi at 3
Set the ram divider at 266 (to ensure you are not held back by ram)
Then begin to increase the HTT by 10 or so. Reboot, go into windows and test for stability with:
SuperPi
http://files.extremeoverclocking.com/file.php?f=36
Prime95
http://www.mersenne.org/freesoft.htm
if stable, continue. Once you find you are instable, drop down by 10 and retest for stability. Once stability is achieved you can move up your ram settings.
Post stability HTT settings here and then you can get help with the ram.
That's the worst manual I have ever seen. It gives almost no bios settings although they are in the system.
R
Discussion Starter #16
ok will do!
this is for my cpu or my mother board?
and ALL of this can be done in the bios?
I dont see any of this... ( I am using a laptop to talk and working on my comp)
The options may be there but require changing the "Auto" setting to Advanced, User, Expert or something along those lines. That will, if available, expose the greyed out options.
Hey Jori, I'd love to know your settings. I just got a K8N board for my Sempron 3100+.
My settings currently are:
FSB: 241MHz
VCore:1.55V
Mem: set to 333 but with overclock, running at 392
Mult: x9
even if I lower my mult, I dont seem to be able to push the FSB any higher than it is....my system is sitting at 2.16Ghz and CPU temp is great.....like 31-34C. I tried putting some more voltage into my CPU but it didnt seem to help much.
I just thought seeing as though you have the same mobo if I try emulating your settings I may get some better results....in the mean time I'll keep playing with it.
1 - 20 of 29 Posts
