1 - 14 of 14 Posts
well i just got this crappy comp few weeks ago and today i fianly decided is time to hear what others think of it.
video:[ame="[URL=http://www.youtube.com/watch?v=7fNypdtmf8c]http://www.youtube.com/watch?v=7fNypdtmf8c"]http://www.youtube.com/watch?v=7fNypdtmf8c[/ame[/URL]]
there are specs in video but just to be sure...
Case: AeroCool Syclone II blue (120mm blue LED fan, 120mm fan, 140mm fan)
Mobo: ASUS M4A87TD EVO
CPU: AMD Phenom II X4 965 Black 3.4 GHz (optional OC 4.1 GHz)
CPU cooler: Coolermaster Hyper 212 Plus (upgraded with 2x 120mm blue LED fans)
Graphic: XFX Radeon HD6850 1GB
PSU: XFX PRO650W Core Edition
RAM: G.Skill F3-10666CL7D-4GBXH 4GB (2x2GB) DDR3
so is it worth 700€ (996,80 $), any recomendations?
Originally Posted by LMA-Winter;12997699
ya sorry for that, ill upload another video tomorrow when its brighter =D
ok....I'll view it again tomorrow... do me a quick favor and read my last post on my build log?
the thing is also that i didnt go for the lowest amount of money, but i wanted a good amount of quality... i also orderd a black edition of my GC but they just got out of stock so i had to buy this 1
Case: Its personal preference so I cant say much. Although we can;t see much of it.
Motherboard: Is that the m4a88td EVO or the m4a87td? I thought I saw a glimpse of a 4+1 power phase...which would make it the reg. m4a87td. But it was hard to tell because of the dim lighting... If that is the case and its got the 4+1 just don't overclock with it and it should hold up fine. If it is the EVO then its a pretty solid board.
CPU: its a solid processor but the 955BE would have saved you $20-30 and its only a 200mhz difference. IMO the price difference is not worth the difference in performance.
CPU Cooler: the 212 is a solid performer.
RAM: Specs don't seem quite that good at 1066 but that depends on how much money you spent on the set really.
GPU: the 6850 is a solid budget card IMO and from what I have heard and read.
PSU: the XFX 650w power supply I have heard both good and bad on....more good though. I personally would have gone with a corsair, but thats just me.
For the amount of money spent you could have definately made a much better system, and there are definitely changes I personally would have made. But overall it seems like a decent build to start with.
the case looks like the back of a Star destroyer. must be hard to clean though
· OG AMD
The hardware is very good for a pre-built.Good job.You could have saved yourself about $300 if you built it yourself though.
Discussion Starter · #13 ·
atm cleaning isn't that hard, just a strong air blow and ist clean =)
actually it's not pre-built, i just named it my self, but yea, prices are much higher in our country, so this is the lowest price i cud get for this performance and quality
1 - 14 of 14 Posts
