Last Updated 3/25/12
About the Club
Just a fun club where AMD owners can post their Super Pi scores. Ill update this post as often as possible with your score, CPU, and clock speeds. Anyone can post their scores on here as long as the CPU they are using is AMD.
Rules
Must include a screenshot displaying CPU-Z, Super Pi with the 1 Million run and time visible, must include notepad showing your name and date of post. If there is no date or the date does not match the date you posted the screenshot it will still be accepted if it meets all the other requirements including your name. If you get a better score later feel free to put it back up and your score will be updated.
Rules Exceptions
If you fail to meet any of the rules listed above in your screenshot your score will be listed under the unverified section. If you can provide another score later with an updated screenshot that meets the requirements you will be moved to the verified list.
If you have a screen shot that you would like to put up but it does not have your notepad name in it you can provide a CPU-Z validation that has the same name as your OC.net user name and that matches the specs in CPU-Z on your screenshot in place of your notepad name.
Super Pi
If you haven't heard of Super Pi before, its a program that calculates a specified number of digits of pie. The standard that everyone uses is 1 Million digits. So if you haven't ever tried it before go ahead and download it. Its a very small program and real simple to use.
Current Super Pi Version 1.5
Download
http://www.techpowerup.com/downloads/366/
Submission Example
Once your score is posted on the list feel free too add this to your signature
╥AMD Super Pi Scores Club Member╥
[CENTER][b][URL=http://www.overclock.net/t/1223390/amd-cpu-super-pi-scores-club]╥AMD Super Pi Scores Club Member╥[/URL][/b][/CENTER]
https://docs.google.com/spreadsheet/pub?key=0AoMje7V7fAn9dDh6X1dmTENUT2NvcnpfQzZFR0xGTVE&output=html&widget=true
Unverified Scoreboard
https://docs.google.com/spreadsheet/pub?key=0AoMje7V7fAn9dDlrTGFBRGhfRHRLRDJYcENNYnZNeVE&output=html&widget=true
