1 - 4 of 4 Posts
Right now im running a Athlong II X2 235 at 2.7 Ghz. Im getting into gaming alot more and wanted to be able to run fraps smoothly, which my X2 Fails at. My mobo is a MCP61Pm-GM so i suppose i can get any x3 size chip right?
If i can, im gona invest in the 6 core, my original plan was to switch to the sr2 mobo and get an i7 but i figure ill save a little bit of money if i can just get the X6 and put it in this machine.
My problem is this, ive heard people having problems in that their motherboards have problems with more powerful cpus, i know ill need a better psu (450 right now) but do you think my mobo, which is made by emachines =[ can handle the x6?
Would be really nice if i could!
Discussion Starter #2
I have a problem, the specs on the internet say this mobo is am2, while cpu-id says my X2 is AM3, and the internet says i can only take a 89wat or less cpu =[
I hate to be the bearer of bad news but you will need to upgrade your motherboard, PSU, RAM, and maybe some other parts so you can use the new 6 core processors. Your motherboard also doesn't support PCI-E 2.0 . But you can find basic motherboards that have all the Specs and features you need for around $40-50 on newegg.com . Memory is also cheap. And power supplies you can get for a decent price. I recomended getting a PSU that is at least 80plus certified. And one that has 500w or more just to future proof yourself and to be on the safe side.
Now what do you mean by running fraps smoothly and your x2 fails at it?
I think your graphics card will play a more important role here. That CPU may not be the fastest out there, but it should do what it needs to if you have a pretty good graphics card.
-D
1 - 4 of 4 Posts
