1 - 9 of 9 Posts
Hi wat can i do to achieve this:
AMD X4 555 @ 4 Ghz
I currently have the 555 and am in the market for a mobo, mem and cooler.
I am currently considering:
Mobo:
GIGABYTE GA-770TA-UD3
http://www.newegg.com/Product/Produc...82E16813128419
MSI 770-G45
http://www.newegg.com/Product/Produc...82E16813130250
ASUS M4A785TD-V EVO
http://www.newegg.com/Product/Produc...82E16813131398
ASUS M4A79XTD EVO
http://www.newegg.com/Product/Produc...82E16813131402
Mem:
http://www.newegg.com/Product/Produc...82E16820231277
Cooler:
Corsair H50 recommend some fans to get the job done.
Car cheaper than computer
Vcore.
All you need is a good cooler.
Originally Posted by Idiot View Post
Vcore.
which mobo thou?
AMD X4 555 @ 4 Ghz
Mobo:
MSI 770-G45
ASUS M4A785TD-V EVO
ASUS M4A79XTD EVO
Mem:
Cooler:
Also, keep in mind that your processor may unlock to a X4 and it may not so buy it with the intention of having a dual core and then see where you can go from there.
Also, when it comes to a motherboard, I know that the Gigabyte Boards new BIOS' have specific options for unlocking specifically Core 2 and Core 3 (numbered 0,1,2,3) and then you can test for stability.
Also, your links are broken. But here's a question for you, what's your budget for a motherboard?
one vote for both gigabyte board, if u don't need cross fire option, can save up a 'lil & go for better memory. both should be equally good. g45 is not bad but vcore fluctuate from 0.03~0.05v.
i'm not a fans of asus.
Discussion Starter #6
under 110 mobo
ill prob get the gigabyte board. about the mem ill be able to oc it to 1866 np right. or is it not worth it and i should get the 1333.
The PH IIs Like tight Timings more then ram speed.
If you want a cheap board that is pretty good go for a gigabyte based bored. They're very reliable, most have 60,000 or something hours of capacitor life (little black cylinders, they hold electrons to bring down voltage) most of them have dual BIOS which is good if your overclocking, just some backup. Most of their higher end boards have 2 OZ of copper and have a new testing feature in the BIOS to see if it's stable.
It really depends on what you want, if you want to unlock cores you need a motheboard with the hybrid feature, makes life easy, but it comes down to luck usually.
Good luck it's always hard doing things like this but fun
Discussion Starter #9
like wat? and can u recommend a pair for the gigabyte board.
1 - 9 of 9 Posts
