1 - 10 of 10 Posts
I need help overclocking, ima noob at this..
Stock- 2.0 GHZ
Current=2.3GHZ
First question
Do i overclock with Gigabytes supplied programor thru bios?
So not2bad what ur max oc with ur 3200 venice?
Question number 2
in bios u have thing that u increase like 230....when do i increase my voltage?
I've gotten to about 2.5 but not stable...I really don't like my venice. In the bios you increase the HT as you are doing until your comp can't boot into windows. That's when you bump up the voltage a bit and continue. When you think you have enough then you start testing the stability. Then if it fails those then you bump the voltage up a bit more or if that's already too high you lower your HT back down until it's stable.
Discussion Starter #5
I cant seem to get it over 2.3, what voltage should i have it at for say 2.4?
this is current
have you got your pci locked or set to 66 or 67 mhz, your ht mult set to 3 or 4 x, your ram will need to go on a divider- 166, you cant just start crankng up the htt (fsb), it doesnt work like that.
Discussion Starter #7
English PLZ
How do I go about doing that stuff?
Oh so i take the multi down from 10?
Originally Posted by jbrown
English PLZ
sorry, the HT mult (ratio) has to be kept under or around the 1000mhz mark, so if you are at 250htt(fsb) with a mult of 4x= 1000mhz, not your cpu multiplier, you can leave that at 10x, the ram divider will slow ya mamory down so it doesnt go too fast and be unstable, have a look around ya bios. read this
http://www.overclock.net/amd-general...ing-guide.html
Following are my easy steps to OC to 2500:
250 FSB
10 x multi
HTT x4
Everything else on auto.
My best OC was:
260 FSB
10 x multi
HTT x 3
CPU Vcore 1.5 (or 1.55 whatever max for my mb was)
Everything else auto
1 - 10 of 10 Posts
