Before I'm gonna talk about what I observed as far as RAM speed -> min FPS impact....
Originally Posted by
BradleyW
Thank you for the feedback everyone!
Also, I'm lucky my chip can handle 2400MHz. Most are limited to 1866 on SB-E, some are limited to 2133, I'm limited a little higher than that. 2666 is a no go on my system.
I just got Predator X 2666MHz. The PC runs fine, except both XMP profiles,which are actually shown correctly in UEFI, kinda don't work. Both 2400 and 2666 CL 11 profiles set my RAM speed to 2133 CL9. I thought it was some kind of UEFI problem (although I picked my mem sticks from the official supported list). Are you suggesting that Sandy Bridge chips can actually limit RAM speed ? I ain't found nothing like this on the net, although I've been looking...
OK, back to the results.
Setup1: i5 2500k @4,72GHz, 8GB DDR3 @2240MHz CL9 in dual channel mode, R9 290 Tri-X.
Setup2: the same, except for @1066 CL7 dual channel DDR3 memory
Far Cry 3, Ultra preset, 1080p, mission: deepthroat (complete), run twice to ensure the results are precise.
Run1:
@2240 CL9 min. FPS - 57
@1066 CL7 min. FPS - 43
Run2:
@2240 CL9 min. FPS - 53
@1066 CL7 min. FPS - 42
Quite a difference, right ?
The -4 fps difference between run1 and run2 might've been more of a one-sec HDD freeze, most of the time the game is locked at 60fps, no drops at all.
