1 - 10 of 10 Posts
gonna be used strictly for browsing and doing homework.
goal was to be under $400, cheaper the better.
case: CM RC-120: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119261
mobo: ECS H61H2-I3: http://www.newegg.com/Product/Product.aspx?Item=N82E16813135323
cpu: Celeron G530: http://www.newegg.com/Product/Product.aspx?Item=N82E16819116409
mem: Mushkin DDR3 1066 2x2gb: http://www.newegg.com/Product/Product.aspx?Item=N82E16820146746
psu: Silverstone SST-ST40F 400w: http://www.newegg.com/Product/Product.aspx?Item=N82E16817256060
hdd: WD caviar blue: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136771
odd: LG DVD burner: http://www.newegg.com/Product/Product.aspx?Item=N82E16827136259
wireless: Rosewill pcie 1x: http://www.newegg.com/Product/Product.aspx?Item=N82E16833166047
total comes to $323.92
mouse, key board and monitor and not needed as he already has them.
thoughts? suggestions?
Not New to Overclock.net
for the sole purpose of doing homework this will be just fine for him
the mobo is deactivated though..
If he want's a little more (I've used photoshop, etc for hmwk) a 60gb ssd and 4-8 gb ram would serve him well. I've found my current i3 3225, 8gb of ram and ssd to kick my old i7 920+12gb ram+ huge hdd in the ****. in any case, I would go for the 4-8gb of ram as the difference in $ is minimal.
another thought: when I'm researching I'll have 30+ tabs open at the same time. I've seen browser mem usage as high as 1gb. and there's nothing worse than hangs when you need to finish a paper. so I think 4gb of ram is a no brainer.
Discussion Starter · #8 ·
Originally Posted by adriangb View Post
And some savings could come from:
pico PSU (if he has a power brick). This should be good enough: http://www.amazon.com/Mini-Box-picoPSU-80-Output-Input-Supply/dp/B005TWE5E6/ref=sr_1_1?s=electronics&ie=UTF8&qid=1361740768&sr=1-1&keywords=picopsu
ditching the dvd burner (if there's another one available, he can just transfer the ISO, use pen-drives, etc)
With that freed up you could go for the 4gb mem and a 60gb ssd for like $40 more
hes not very computer savvy in the slightest, so ISOs and pen-drives would just confuse the living crap out of him so the burner needs to stay.
ill do a little digging into the pico psu. never used one before.
or go this route
http://www.amazon.com/MI-008-Tower-Black-Chassis-Supply/dp/B001H0BA24/ref=pd_sim_e_2
Still kinda lost
1 - 10 of 10 Posts
