Status
Not open for further replies.
1 - 3 of 3 Posts
The Zotac "Crown Edition-ZT-Z68 U1DU3" is a Z68 motherboard in the Extended ATX (E-ATX, 330x305 mm) format. At that size, you know from the start that it will only fit a select number of cases. But in an attempt to woo gamers, enthusiasts and overclockers, Zotac have piled it all on the details:
- a 26-phase design (24 for the CPU), with driver-MOSFETs, solid chokes, high-C and super ML capacitors,
- 802.11n onboard Wifi mini-PCIe Card (as well as gigabit Ethernet),
- an NF200 chip to support 32 PCIe lanes for a 16x/0x/16x/0x or 8x/8x/8x/8x GPU configuration,
- two onboard USB 3.0 headers offering four ports (as well as two on the back),
- three BIOS chips for backup BIOSes (not sure how this fits in with Gigabyte's DualBIOS patent),
- a legacy IDE port, and a mSATA port for an SSD,
- quad-SLI support,
- voltage read points
rest of article
Is that a record number of phases for a socket?
1 - 3 of 3 Posts
Status
