Hello
I've been getting really bad lag spikes on many games, (1280x720 with highest settings as possible that I don't get lag spike, if I do manage to max it out, I got for AA/AF.) That's what I usually do.
Since im using 890FX, I want an ATI Card, I was thinking of this, at a mere 100$ish
http://www.canadacomputers.com/produ...item_id=039508
Should I go with that?
If you want to suggest anything else, I would prefer
- buying from http://www.canadacomputers.com OR http://www.tigerdirect.ca
- Radeon HD (Doesn't have to be DX11) - I might xfire later on
- A mere 120$
Any suggestions? I'm getting the upgrade in like the next 24 hours.
Another question, if I go with that ASUS 6670, what resolution/settings should I aim for games like Crysis 2 and BFBC2? (I maxed out BC2 with GT240 execept HBAO and AA/AF (Both at 1x) Tweaked Crysis2 a bit with Advanced Graphics to medium with AA/AF Off, still lagging pretty badly.
I think the DDR2 667 Ram that's on my GT240 really limiting here.
Thanks for reading this wall of text and for suggesting (if you do).
- A mere 120$
