Hello, for the past months I struggle with stability issues on my r7 5800x. Right now I get black screens/restarts even while watching youtube. The history and the solutions that I have tried are many and span a number of months so i will provide a full history at the end of this post if you have the time to read it.
Right now my system consists of a r7 5800x (4month old), msi b550 gaming edge wifi (4month old), gskill ripjaws 2x8gb 3200mhz (bought in late 2018), a Thermaltake smart se 530w (i know its bad (bought in late 2018)) and a be quiet dark rock slim + a 6600xt . I have updated the bios to the latest stable one ( just 4 days ago) and i have only enabled xmp. Yet the system blackscreens and restarts. The timing is weird It happens every week or couple of days and then it stops for a couple of days, when it does happen i get a couple of crashes back to back with varying frequency. The crashes come with the same WHEA errors about Cache Hierarchy Error on pretty much all the APIC ID (most common i suppose is APIC ID 2, 12,14. best cores are 3, 7, 1, 2, 6, 5, 4, 8 ) (look at screenshot for periodicity of the errors ).
Thats pretty much the gist of the issue. Its unstable even at default settings (pbo auto) with just xmp enabled i don't think 3200 is pushing the memory controller, what chould be the cause of this ?
For a more detailed description.
I bought the 5800x and the b550 mobo 5 months ago to upgrade my r5 2600, b450 system. so the ram and the psu is repurposed from a system that was running just fine for about 3 and a half years.
First I didnt knew much about PBO oc so I just enabled it set ppt to 120 , tdc 95, edc 120. and curve optimizer -20 "bad cores" - 15 the two "good" cores and max turbo +50mhz. The system run fine with no crashes for about 2 months. 0 problems in multithreaded applications or single threaded and it frequently boosted to 4850-4900 while gaming. Suddenly 2 months later the crashed started in extreme intensity, meaning the pc would constantly crash back to back even while just trying to browse my files(so i doubt it the usual instability that is observed with pbo one in a blue moon because two months is a long time) .
Then the struggle started, At first i tried core cycler, I run it for many nights (trying different settings per core and different FFTs always for more than 2 iterations of 1hour per core) I found the "stable settings"-nothing extreme best cores at -3 bad cores at -20 and some at -13- that gave me no errors and the crashes stopped.(at the same time i tried using xmp off and even pbo off)
After some weeks of perfect stability the same thing happend, the pc started being extremely unstable. I further increased the curve settings till it was stable for a couple of days/weeks. Then it would once again go into an extreme crashing period where the once perfectly stable system would continuously crash many times a day.
The same pattern of: no crashes for weeks followed by many crashes in a single day remedied by me increasing the curve settings (always run core cycler to check for errors) would continue for many weeks till i reached positive number in some cores to make them "stable".
Now I gave up on curve optimizer i put everything in default except xmp, the system run for a couple of days and then started crashing again so 4 days ago I flashed the newest bios and again 4 days with no crashed and today it crashed twice one in YouTube and once in a game. For a last resort (before trying pbo off and performing an all core traditional oc pr just leaving it with the old boost technology) I enabled curve optimizer all core to positive +5.
I have tried using loadline calibration control for both cpu and soc voltages (soc stays at 1.0 even at prime 95)
I have tinkered with the gpu, performing ddu installations of the drivers various oc settings and I can say that this was not the issue right now it is just running with a power limit +20 setting.
I cant think of anything else to do now, and it has started really exhausting me, i am afraid of using it nowadays. I dont want to admit it to myself but maybe i have a bad cpu and i need to send it back which is a big pain since this is my main computer. I suppose maybe the mobo or the gpu chould be at fault or more possibly that sketchy, old, psu. Or even my installation of windows? Maybe the chipset drivers? Who knows even my house power wiring might be at fault and any power surge in the system from a different defice like an AC or a washing machine affect its.
I waited this long to post it because till now i was overclocking but now we are at stock. I have read many threads on ryzen 5800x issues but i ve never seen this particular behavior.
Thank you for reading my whining post.
Take a look at the periodicity of the errors bellow in case i didn't explained it well. I have colored them in "blocks" keep in mind that every crash grouping is accompanied by me not doing anything for the first few crashes of the grouping and then changing the settings.
