Antec 300 Illusion w/ small problem
557 Views 11 Replies 9 Participants Last post by  Carlitos714
I would like to know what to sell my Antec 300 for, as I plan to get a Lian Li ATX Mini tower after Christmas (Maybe sooner, depending on how much I could sell this for)
Its an Antec 300 w/ 2 front fans, and a top 140mm fan w/ Blue LED's (The ability to mount a fan on the back and on the side panel)
The problem:I was trying to put a custom thumb screw in the case and the head broke off, leaving the actual screw in the case, you can still put the side panel on and screw it in one of the screw. You could drill the screw out (its a cheap screw made out of metal and plastic) I just don't care to do it.
1 - 12 of 12 Posts
I highly doubt that tiny problem will affect the cost at all. It would take less than 3 minutes to fix it. I would say $40US.
I'd say 40 High, 30 low.
They go for 59 bucks, and depending on deals, most the time go for 49.99 USD.
Thanks, I'm thinking $40 USD
So i'm looking at $40-$45.
Antec 300 Illusion goes for $69.99 and regular antec 300 goes for $59.99. I would say $45-$50 shipped.
iirc, Antec sells those fans for $20 a piece. Sell it for $40 and you're basically selling the fans and giving the case away for free. However, people probably aren't willing to spend more than $50.
What I would do is take the front fans out, sell them for $10 each, then sell the case for $35-40 shipped.
Really? Might do that.
40 shipped. honestly i dont think those fans will sell for 10 a piece.
1 - 12 of 12 Posts
