1 - 4 of 4 Posts
Hi, I have my antec 620 connected to CPU_FAN, but can be connected to chasis_fan pump connector? not damage the pump? the connector so CPU_FAN connect a 4 pin fan cooler master excalibur
thanks..
I've always noticed that when connecting a CPU cooler to chassis fan connectors results in the mobo delivering less power to the fan. I'd think it's best that you try to connect it to a CPU connector but if you have to connect it to a chassis fan connector then try to get it to run at max.
thanks for the reply..
Now tested and installed in the pump and so PWR_FAN runs at maximum ..
1 - 4 of 4 Posts
