1 - 2 of 2 Posts
Good at all .. I am having a doubt .. for Wednesday would come my antec 620 and would like to know the position of the radiator .. I have a 690 cabinet advance II have to put up two 140mm coolers .. My question is whether it would be well placed the radiator at the top? or put it in the back as shown in several reviews?
WC according to corsair in air indicates that mess out .. antec but says nothing of this .. most places drawing air from the inside out .. which position is better then?
thanks from now ..
It depends on the airflow in your case. I have more intake on the side than from the front, so I prefer exhausting my radiator on the top of my case. However, with my old build, I had 3 intake fans in the front of my case and none on the side, so I preferred to exhaust my rad at the back. You can always try both configurations and see which yields better results temperature-wise.
1 - 2 of 2 Posts
