Antec 900's side panel?
530 Views 8 Replies 5 Participants Last post by  AMOCO
Hello
For Antec900's side panel, is the mesh covered with acrylic/plastic? since i plan on tying 4x80mm fans on the mesh of the side panel once i purchase this case.
thanks!
1 - 9 of 9 Posts
I am pretty sure it'll work, ive seen lots of people here do the same thing as you're trying to do.
i think it acrylic paint.i have a 120mm zip tied to the top of mine where the 200mm goes,wait it to come back from RMA.
im not asking about the TOP!
is the side panel MESH covered in plastic? yes or no?
There is plastic behind the mesh. The plastic comes off with a few screws.
the top mash & the side are painted with the same paint.
exact answer i was looknig for thanks
not the paint thankyou very much... i asked for plastic.. not paint
The side mash has plastic behind it but it can be removed.
is the mesh covered with acrylic/plastic?:::::::::this what you asked.
1 - 9 of 9 Posts
