1 - 4 of 4 Posts
I had a question about my new DF 85 and I just can't find the answer. My question: Is the 2.5" hot swap bay at the top SATA 2 or SATA 3?
Storage Nut
Sata 2
Thank you.
It is what your board makes it. The cable itself, and the board attached to make it hotswap are not the determining factor. I have mine plugged in to my SATA III 6GB ports and it runs at that speed. So, the question is, is your board SATA III? If so, then its going to be III
1 - 4 of 4 Posts
