Antec Inc Kuhler H2O 920 Cooling System Mountable Dual 120 Mm Pulse Width Modulation Fans
Description:
Antec's KUHLER H2O 920 provides maximum-performance liquid cooling for your CPU in a quick, easy-to-install package. Unlike traditional liquid cooling systems, this self-contained unit comes prefilled and requires no maintenance. The dual 120 mm Pulse Width Modulation (PWM) fans and 3rd generation copper coldplate ensure quiet, efficient cooling, while the 49 mm radiator is equipped to handle the highest performing CPUs on the market. Lastly, the included software helps you monitor and control the Khler H2O 920s performance and allows you to customize its stylish RGB LED. Fan Speed: 700 - 2400 RPM (PWM controlled). Tubing Length: 13.0". Radiator Dimensions: 5.6" (H) x 4.7" (W) x 1.9" (D). Fan Dimensions: 4.7" x 1.0". Air Flow: 110.0 CFM. Noise Level: 43 dBA. Cold Plate + Pump Height: 1.1". Compatibility: Intel Sockets: LGA775. LGA1155. LGA1156. LGA1366. AMD Sockets: AM2. AM3. AM2+. AM3+. Green Compliance: Yes. Green Compliance Certificate/Authority: RoHS.
Details:
Description:
Details:
Detail | Value |
Binding | Personal Computers |
Brand | Antec |
Feature | Included software provides essential tools to control and monitor the KUHLER HO 920. Non-corrugated easy-bend tubes for maximum flexibility in radiator positioning. Pulse Width Modulation (PWM) radiator fans generate the quietest high performance cooling. Customizable RGB LED creates brilliant illumination. Cooling Liquid - Safe, environmentally-friendly, anti-corrosive. |
Label | Antec Inc |
Manufacturer | Antec Inc |
MPN | B19KUHLERH2O920112 |
Publisher | Antec Inc |
SKU | ARDHKUHLERH2O920B19112 |
Studio | Antec Inc |
Title | Antec Inc Kuhler H2O 920 Cooling System Mountable Dual 120 Mm Pulse Width Modulation Fans |
PartNumber | B19KUHLERH2O920112 |
ProductGroup | PC Accessory |
ProductTypeName | COMPUTER_COOLING_DEVICE |
