I would like to create an opening in the side panel to access the heatsink backplate without completely having to remove the entire motherboard when swapping the heatsink. Many cases already have this as a stock feature, but not the P182.
I have 2 questions:
1. Is a Dremel the correct tool for this (7.2v)?
2. Will a Sheet Metal bit work or do you think I should use a wheel accesory instead?
If anyone who has done similar projects has helpful pointers or suggestions, your feedback is greatly appreciated! Thanks in advance for your help.
I have 2 questions:
