Hey! I was looking around and I saw the Antec P190 case on xyzcomputering. I was wondering if it was possible to mount a 240mm water cooling radiator* where the two top exhaust fans are. If this would work you could have internal water cooling which would be awesome. But, I think it might be a squeeze, considering, the Upper & Lower Chamber Design + an ATX motherboard. If this does work I can just place a Koolance RP-1000BK or another Reserverior + Pump Combo and everything will be out of the way and in the case, also, I could hide the extra tubing in the 5.25" bay. Making a quiet, simple, and clean water cooling setup with a silent rig.
*The demensions of the Radiator are 10.75" x 5.25" x 1.77".*
Ideas? Comments? Feedback? It's all welcome.
Thanks,
[OCN] Ninja_Boy
Linkage:
Black Ice Xtreme II
Koolance RP-1000BK
Antec P190B ATX Case
Thanks,
[OCN] Ninja_Boy
Linkage:
Black Ice Xtreme II
Koolance RP-1000BK
