the P180 is a big heavy case. my doors aren't warped like what others have experienced.
Pros for me:
inside layout
outer design isn't flashy
different thermal zones for PSU and Mobo
rubber grommets for HDs
two easy to reach air filters
noise dampening panels + choice components = a quiet machine
Cons:
big and heavy
i don't regret getting the case. my advise for you is to get an extension for the 4pin 12v
here. i have mine setup so that i don't have any wires running across the middle of my mother board. if you use a fan controller, get some extensions for those too so you can tuck those out of the way.
here's an example of a crazy clean wire job with a P180. this
guy did a sweet job with his case.
