1 - 10 of 10 Posts
So, in a freak accident, I decided that it would be a good thing if I ripped out the two usb ports on the front of my Lanboy. I was wondering if anyone knew of a way to replace those ports.
When you say "ripped out", did you break any of the tabs or retainers, or whatever held the ports in place.<br />
<br />
And what would be the criteria to qualify this action as "a good idea"? <img src="/images/smilies/confused.gif" border="0" alt="" title="Confused" class="inlineimg" /> <br />
<br />
I've heard duct-tape does it all...<img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /> <br />
<br />
JK... post a pic or two of the damage.
I just need to find my camera and I will post some pics.
<div>Originally Posted by <strong>BaLarry19</strong> <a href="showthread.php?s=f0ff622456a527c34b14aeab359ee59d&p=1396017#post1396017"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">I just need to find my camera and I will post some pics.</div>
</td>
</tr></table></div>
*waits patiently...*
Discussion Starter #5
<a href="http://img183.imageshack.us/my.php?image=dscn1544iv1.jpg" target="_blank"><img alt="" src="http://img183.imageshack.us/img183/2025/dscn1544iv1.th.jpg" style="border:0px solid;"></a><br><a href="http://img241.imageshack.us/my.php?image=dscn1546jo5.jpg" target="_blank"><img alt="" src="http://img241.imageshack.us/img241/125/dscn1546jo5.th.jpg" style="border:0px solid;"></a><br><a href="http://img241.imageshack.us/my.php?image=dscn1547um7.jpg" target="_blank"><img alt="" src="http://img241.imageshack.us/img241/7571/dscn1547um7.th.jpg" style="border:0px solid;"></a><br><br>
So both of the white tabs broke off of the port and also, the middle metal piece came out as well.
Is that "middle piece" part of the phusical interface, or is it part of the retaining mechanism. Also, it looks like the piece is aluminum/aluminium...<br />
<br />
Super glue and a steady hand ought to re-attach the plastic parts. but metals?.... not sure.<br />
<br />
Does the port itself function? If so you might just run it "backwards" through the opening and simply have it hanging from the hole....not very ellegant, but functional.
Discussion Starter #7
I'm going to try to super glue it back together. The port still works, its just that there is nothing to hold a cable in place right now so the connection is alway lost.
<div>Originally Posted by <strong>BaLarry19</strong> <a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1397324#post1397324"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">I'm going to try to super glue it back together. The port still works, its just that there is nothing to hold a cable in place right now so the connection is alway lost.</div>
</td>
</tr></table></div>
Electrical or Duct tape are both your friends...<img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
Discussion Starter #9
So far I haven't had any luck. I need to get some tape though.
<div>Originally Posted by <strong>BaLarry19</strong> <a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1399101#post1399101"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">So far I haven't had any luck. I need to get some tape though.</div>
</td>
</tr></table></div>
Contact Antec for replacement parts. they can get you anything and everything you need. Its better then bodging it together.<br><br>
try contacting them using one of the methods on this <a href="http://www.antec.com/us/info_contact.php?value=us&Submit=Submit" target="_blank">list.</a><br><br>
I had a email addy for the replacement parts, need to find it.
1 - 10 of 10 Posts
