any 4850 crossfires out there with oc?
356 Views 6 Replies 3 Participants Last post by  We Gone
I cant seem to oc these things at all.
they overclock fine, one at a time. but not in crossfire
some one shed some light please
got the new visiontec 4850s the revised ones that dont get over 50c
1 - 7 of 7 Posts
Could you elaborate please?
They don't achieve the same speeds as they did when single, or they won't oc at all?
Have you tried the auto overclock in CCC? Does GPU-Z show both cards with CF ?
I use the ati catalyst center. when i try to do the auto oc . it gets up to 655 core and 1043mem. on both
however its not stable there.
or anywhere near it.
Have you tried to reinstall the drivers after you hooked up CF? I had a stabilty issue when I first set up CF and it was a power supply issue..but I see you should have that covered.
yes.
power isnt an issue.
This was posted a while back..Hope it helps ya.
http://www.tweakguides.com/ATICAT_1.html
1 - 7 of 7 Posts
