1 - 5 of 5 Posts
just set this system up should be in my info but if not its a AMD 3.1 triplecore unlocked to a phenom x4 b45 mobo is ASUS M4A77T/USB3 ram is adata ddr3 1600
kept same multiplier at 15.5x bus is at 250, Ht at 2000, CPU-Z is showing cpu speed of 3875mhz and core volts at 1.384 (its on auto). ram runnin at 833.4mhz atm
just wanting to know if these settings are good or if i got the HT wrong or something....pretty good overclock so far...going for new cpu cooler soon still on stock so runnin a bit warm (53C idle while OC 40C idle at stock)
other question is...ram timings...i got it set at 9-9-9-24-33 like it shoud be (not sure about the 33 thats auto)...but there are like 20 other settings below those that i cant figure out what to set to...or should i just leave em on auto? posted pic of cpuz figures so u can see
I would definitly wait for the new cooler before overclocking but thats a personnal choice
. Have you ran any stress tests such as prime 95 or occt ? I'm not sure but I think the vcore could be a little bit higher. I'm no expert tho, just tryin to help...
4GHz
Don't touch what you don't know is a pretty good rule of thumb
Make sure, y'know, that you're stable before going on and pushing the limits even further.
Discussion Starter #4
havent ran any stress test....temp is just too high to wanna try it...even at stock it gets up to 59C under full load when i was testing the 4th core..so will just have to wait till i get a new cooler....dropped back down to stock speeds for now.
4GHz
Well, you can't know until you try, of course. Not going to magically kill your CPU if it's above 70 for a bit.
1 - 5 of 5 Posts
