1 - 8 of 8 Posts
I am looking for anyone who has a ASUS A8N-E S939 mobo who overclocks, preferable with an AMD X2 cpu? Here are some things I would like to know:<br><br>
1) Your overclock with the board and cpu?<br>
2) The maximum FSB you can get out of the A8N-E?<br>
3) The maximum vcore you can put on a X2 cpu with that board?<br><br>
ty
I have not tried the max FSB bus but my oc is 2640. I will post the max v core later.
Ok thanks, I am guessing thats 240x11? <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink"><br><br>
Oh and what vcore are you using at 2.64GHz? Stock?<br><br>
I need to know what the FSB wall on the A8N-E is and whats the max vcore it will allow you to do (some say max in bios is only 1.45v)<br><br>
I need to know as this will help me decide on what X2 cpu I will buy as the X2 3800+ sounds cheap and a good overclocker, but I do not want to be FSB limited (ideally wanna hit 300FSB here), so I say what about the X2 4200+? Little bit more cash, but has a 11x multi which should remove any FSB wall.<br><br>
Then I say what about the X2 4400+, it has 2MB Cache, is it better for OCing? Does twice as much cache make a difference?
ok, I shut down to get it for you, here it is 400fsb and 1.55 v core and yes I am running 220x11. To run 2.6 I am running 1.5
Reactions: OCZedd
Discussion Starter #5
OK, that clears things up <img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb"><br><br>
So 400Mhz FSB stable? Cos that massive <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"> And I thought there was a 1.45v Vcore limit on X2 cpu's? Guess I heard wrong. Thanks.
Sorry I don't know what the max fsb I could run but it allows up to 400.
Discussion Starter #7
Ah i see. No worries, hopefully someone else will tell us. <img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick Out Tongue"><br><br>
I just wanna know so I dont mess up on my cpu choice. But you sure it allows 1.55v? Just double checking that u meant 1.55?<br><br>
Edit: Ok, i believe you bcos u said you are running at 1.5 @ 2.6GHz. It is just me or is that a bit high for just 400MHz inc.? What is your temp btw?
1 - 8 of 8 Posts
