There is no right way of applying TIM in absolute, there are just a few guidelines that you need to keep in mind when applying TIM. Also there is no special method of applying TIM on C2D, you do it the same way for all modern CPUs (not considering those without IHS) out there.
Generally you should use a single drop "about the size of a pea". The thermal paste will automatically spread out evenly when you install the cooler
Edit: I know that's not the TRUE, it's just a random image I selected to show you what I mean.
