21 - 28 of 28 Posts
MAG Z690 TOMAHAWK WIFI DDR4-12900K-4x8GB VIPER STEEL 4400CL19-NH U12A- 980 PRO-SUPERNOVA1000G6-RV02
Those settings are mostly cosmetic - to reduce WTR_L, you reduce tWRRD_sg 馃ぁ
Font Screenshot Software Audio equipment Electronic device
Font Number Parallel Screenshot Pattern
Rectangle Font Parallel Screenshot Technology
And yes, you set that BIOS setting to 28 instead of 30.
Just make sure CPU AUX is increased to 1.91v and procODT is "[15]" instead of "[13]", otherwise it might error occasionally 馃ぁ
my friend what about DRAM V ?
SA V and VDDQ V ?
You have some suggestions for this 4 sticks on 4200G1 ?
DRAM Voltage is a case of silicon lottery, better luck yields lower values for the same settings, worse luck - higher.
On these sticks, when running proper procODT/RTT settings, I've noticed that they require about +0.06v per 100 MCLK
i.e. if 3600 15-15-15 runs at a minimum stable voltage of 1.34v, then 3800 15-15-15 will require 1.40v, and 4000 15-15-15 will require 1.46v ...
(my dual-rank tridentz 3200 14-14-14 kit required +0.08v per 100 MCLK, so 0.06v is not "guaranteed")
Primary timings may still be down to luck, but they've required +/- 0.09v thus far on all but the most insane sticks.
i.e. if 3800 15-15-15 "requires" 1.41v, then 3800 14-14-14 will probably run at 1.50v +/- 0.01v rounding errors
SA and VDDQ are completely down to your CPU's memory controller, but generally then I've found VDDQ to require +0.05v every 100 MCLK, or each -1 primary (i.e. 15-15-15 --> 14-14-14)
SA Voltage I haven't found to require going up or down from the maximum your CPU does stable, but my CPU seems a little unusual in that it goes up to 1.30v and then no further.
So if you find the minimum required VDDQ that runs 3800 15-15-15 stable, and the minimum DRAM voltage, then you can start predicting voltages at higher/lower frequencies.
My memeory controller bends over backwards past ~3848 MT/s Gear1 in 4x8, even if 4200 15-15-15 trains and doesn't crash in light loads - it insta-BSOD's in 100% load scenarios.
p.s. handy tool for memory tarrot card readings: https://dl.dropbox.com/s/qnf2cckk5iqu4uo/testmem5_with_sheet2.zip
ThnX @Bloax Tipping point for me being 3900, which requires 1.47 with below settings and all 4 parks @ 48 (mind u, i use the same settings @ 3866 at 1.44v)
Rectangle Font Screenshot Parallel Number
Reactions: KyKo.
Discussion Starter · #28 · (Edited)
@Bloax My first attempt to get 4000 CL16 stable so far only set the Primary to 16 16 16 the rest was on Auto
Passed y-cruncher 2.5B without any issues which is a good sign. The board has no issues booting ProODT 28.
Computer Font Screenshot Line Software
Also did a quick test with TM5
Azure Rectangle Font Line Screenshot
21 - 28 of 28 Posts
