1 - 2 of 2 Posts
Unwilling Beta tester
So I'm looking for a pump and fan controller which I can use to slow my pump down a bit and control my fans by water temperature. I looked at the Aquero 5 but dismissed it because I can't justify the cost (although that doesn't usually stop me).
I was thinking of using the T-balancer MiniNG which I can get for $37 from Aquatuning US. Seems to be what I want; a cheap internal fan controller which can handle my pump on 1 channel and 4 fans on the other (I checked the starting current and it is within spec).
I was wondering if anyone had any experience, good or bad, with it or could think of an alternative along the same lines.
+rep as always for helpful replies.
1 - 2 of 2 Posts
