1 - 7 of 7 Posts
Since my current mobo is maxed out due to limiting my bus to 232 max, I have been searching for 939 mobo worthy of my opty 165. I am leaning towards the tforce 6100, but ran across the ATI RS485 . Anyone have any experience with it?<br />
<br />
<a href="http://www.evertek.com/viewpart.asp?auto=25725" target="_blank">http://www.evertek.com/viewpart.asp?auto=25725</a><br />
<br />
Thanks<br />
<br />
druid
I remember reading that the majority of the ATI chipsets for the s939, not including the cx3200, were terrible at OCing. I'd avoid them if I were you<br><br>
When it comes to s939 there nothing better than the DFI Ultra-D, you should look into getting one over anything else
If you want to take the greatest of the cheap, then look no futher. Asrock Dual Sata2 or VSTA.Terribly good at OC without the pocket damage of a DFI. Although there is no question that DFI is the best. Asrock Dual Sata2 is good enough for me though<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
Filthy Casual
DFI makes a Crossfire LANParty mobo that should OC well and is under $100... I'll find the link<br />
<br />
Here's the CF one: <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813136165" target="_blank">http://www.newegg.com/Product/Produc...82E16813136165</a><br />
The Ultra-D: <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813136152" target="_blank">http://www.newegg.com/Product/Produc...82E16813136152</a>
Nice Find<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" /> I stand corrected.
MSI neo4-f <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
Filthy Casual
As much as I love this board, no way it could best an Ultra-D at OCing. Though I did get mine to boot at 340 FSB aT 1.425 Volts... but still....
1 - 7 of 7 Posts
