Any good overclock setups for Corsair DOMINATOR PLATINUM RGB DDR5 32GB (2x16GB) 5600MHz C36
1855 17
I'd like to push this ram up further and I'm wondering if anyone has these set up too. I'm kind of new with overclocking as well.
this is also the ram for reference: (speed at 5600Mhz
Corsair DOMINATOR PLATINUM RGB DDR5 32GB (2x16GB) 5600MHz C36 Intel Optimized Desktop Memory (Onboard Voltage Regulation, Patented CORSAIR DHX Cooling, 12 Ultra-Bright CAPELLIX RGB LEDs) White at Amazon.com
the board im using is :
MSI Z690 Force Wi-Fi Gaming Motherboard with speed up to 6666MHz
DDR4/DDR5 Memory SupportDDR5-6666+MHz(OC)
Amazon.com: MSI Z690 Force WiFi Gaming Motherboard (ATX, 12th Gen Intel Core, LGA 1700 Socket, DDR5, PCIe 4, CFX, M.2 Slots, Wi-Fi 6E) : Electronics
its bios is: MSI Click bios 5
Processor : i9-12900K
Motherboard : MSI Z690 Force Wi-Fi
GPU : soon (integrated Intel UHD Graphics 770 )
Powersupply :Corsair RM 750
Ram : Corsair DOMINATOR PLATINUM RGB DDR5 32GB (2x16GB) 5600MHz C36
Liquid Cooler : MSI MAG CORELIQUID 360R V2 White Limite Edition
Case: KEDIERS Diamond Pyramid ATX PC Case Innovative Gaming Computer Tower Case,C600
Let me know what setups and speeds you put for your ram if you have same ram :D
Automotive lighting Purple Hood Automotive design Gas
1 - 18 of 18 Posts
PC Evangelist
Check if they are Hynix or Samsung. Hynix you can do up to 6600, Samsung up to 6000.
PC Evangelist
Go ham:
Could do 6200 with a G.Skill kit with Samsung ICs - couldn't do any more than 6200 with Hynix ICs (tried G.Skill and Corsair Dom Plats like the OP).
I have a Z690 ACE, and in general from what I've seen for four-DIMM MSI boards like ours, that top speed is unobtanium. Buildzoid is using a two-DIMM board in the video.
PC Evangelist
I am using Hynix OEM stick and got 6600 CL32-39-39-28 with ASUS Hero no problem. Had it even at 6800MHz but did not try to get it stable with no RAM heatsinks.
Madonion.com
BZ's vids are good for entry level basic stuff. Normally I'd say real forums like XS but those don't exist anymore, so you're left with trial and error unfortunately. Bits and pieces of info can be found here and there as a starting point, but you're gonna have to figure it out by yourself.
I can boot at 6600 - but it wouldn't stabilize. Don't think I bothered to try harder. However, MSI did just put out another BIOS for the ACE, so I'm going to see how that goes.
im back to try pushing my ram to 6000mhz
so far no luck, im using memory try it, the only thing i dont understand is timings
The Msi pro a ddr5 5600 running at 6000 thru mem try it moved timings from 36-36-36-76 to 36-38-38-86 and mem volts from 1.265 to 1.36 volts all auto. This is on a 12400 so SA locked at 0.935v and imc on auto is 1.3v. Didn’t do no stress tests but zero crashes and the fam like to run rust which uses 20 gb of ram in game. So far so good.
Discussion Starter · #18 ·
Won’t even boot at 6000?
yea pertty stable so far :D those timings did work on mine too
Font Rectangle Screenshot Electronic device Software
Font Screenshot Technology Electronic device Parallel
Product Font Screenshot Electronic device Technology
1 - 18 of 18 Posts
