1 - 2 of 2 Posts
I made a code button to retrieve and display a BOOK record based on the ID typed into the textbox. I suppose to assign all BOOK object properties to the textboxes. But unfortunately, when i click the Find button nothing happens.
Here is my code from my Form1:
protected void btnFind_Click(object sender, EventArgs e)
try
int iBookID = Convert.ToInt32(this.txtSearch.Text);
string sCnxn = ConfigurationManager.AppSettings["Cnxn"];
string sLogPath = ConfigurationManager.AppSettings["LogPath"];
Books oBookSearch = new Books(sCnxn, iBookID, sLogPath);
if (oBookSearch.ContainsKey(iBookID))
this.txtBookTitle.Text = oBookSearch[iBookID].BookTitle.ToString();
this.txtAuthorName.Text = oBookSearch[iBookID].AuthorName.ToString();
this.txtLenght.Text = oBookSearch[iBookID].Lenght.ToString();
this.txtDateCreated.Text = oBooks[iBookID].DateCreated.ToString();
if (oBooks[iBookID].IsOnAmazon.ToString().ToUpper() == "TRUE")
this.chkIsOnAmazon.Checked = true;
else
this.chkIsOnAmazon.Checked = false;
this.txtSearch.Text = "";
catch (Exception ex)
this.lblError.Text = ex.Message;
And this is my code to the BOOK i BUILD:
public Books(string sCnxn, int iBookID, string sLogPath)
try
SqlConnection oCnxn = new SqlConnection(sCnxn);
SqlCommand oCmd = new SqlCommand();
oCmd.Connection = oCnxn;
oCmd.CommandType = CommandType.StoredProcedure;
oCmd.CommandText = "spBookSearchID";
oCmd.Parameters.AddWithValue("@BookID", iBookID);
oCnxn.Open();
SqlDataReader oReader = oCmd.ExecuteReader();
while (oReader.Read())
Book oBookSearch = new Book();
oBookSearch.BookTitle = oReader["BookTitle"].ToString();
oBookSearch.AuthorName = oReader["AuthorName"].ToString();
oBookSearch.Lenght = Convert.ToInt32(oReader["Lenght"]);
oBookSearch.IsOnAmazon = Convert.ToBoolean(oReader["IsOnAmazon"]);
oBookSearch.BookID = Convert.ToInt32(oReader["BookID"]);
oBookSearch.DateCreated = oReader["DateCreated"].ToString();
if (!this.ContainsKey(oBookSearch.BookID))
this.Add(oBookSearch.BookID, oBookSearch);
oCnxn.Close();
Log oLog = new Log();
oLog.LogError("BookSearchConstructor", ex.Message, sLogPath);
Any help would be really appreciated :)
Use code blocks. I helped you out last week asking 2x that you do that. As a person learning computer science you understand how to use some WYSIWYG tools.
1 - 2 of 2 Posts
