Any P67 boards that have space for air-cooled SLI/Crossfire?
On X58 boards you can grab a 10cm crossfire bridge and use the 1st and 3rd PCI-E slots for multi-GPU if you want some extra breathing space between the cards, especially because top cards tend to run hot.
Do all of the P67 boards basically cramp two cards together? I looked at the Asus P67 Sabertooth and there's only two pci slots between the two GPU slots, which means they'd be pushed together.
The P67 Deluxe has 3 GPU slots but the 1st and 3rd are so far apart even an extended 10cm crossfire bridge can't connect them.
If you want good cooling between two GPUs in Xfire/SLI do you pretty much have to go x58, or is there a P67 out there that actually has sensible multi-GPU design?
