1 - 9 of 9 Posts
Does anyone know any 1440p monitors with bigger Hz than 60, or 1080p with more than 60 Hz
I found a Acer G277HUsmidp and I dont know why but this monitor is only 371 EU at my country it has 1440p, 1ms, 120Hz.
Any other recommendations.
Military grade Garbage
Originally Posted by Poisoner View Post
Didn't acer just unveil a 2560x1440 144hz freesync monitor at CES?
144hz, IPS, 1440p monitor to be exact
Originally Posted by the_bears View Post
Yes but it wont be avaible in my country for a while.
Then the acer one you found should be more than suitable
Korean.
I like the blur reduction settings BenQ has on their models with blur reduction. (make sure it has the v2 firmware for the settings, though it's been a long while since they rolled that out and you can RMA to get it flashed if old firmware.).
edit: though they don't have a 1440p out yet and their 1080p 27inch is more pricey than the one you asked about.
1 - 9 of 9 Posts
