1 - 19 of 19 Posts
im running a e6400 dual core and using the motherboard as u can see in my system specs i was just wondering should i get this fan <a href="http://umart.net/au/product_info.php?cPath=108_367&products_id=103877" target="_blank">http://umart.net/au/product_info.php...ucts_id=103877</a> or this <a href="http://umart.net/au/product_info.php?cPath=108_367&products_id=103725" target="_blank">http://umart.net/au/product_info.php...ucts_id=103725</a> i just want the better one as i want my comp to stay as cool as possible or possibly even the big typhoon fan, couldnt get the link but u guys should know what the big typhoon is <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick out tounge caps" class="inlineimg" /><br />
whatever one u guys recommend please tell me why and what product out of the 3 would keep my cpu the coolest as possible, cheers
Better post this <a href="http://www.overclock.net/intel-air-cooling/" target="_blank">here</a><br />
EDIT : Stupid post sorry !
He has posted this question once already in the wrong section - Leave it here - the mods can move it <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
<br />
Fix your links mate
Discussion Starter #5
umm sorry about that guys, links should be working now <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">
Discussion Starter #6
need urgent help guys as i have to get the fan really soon and i need ur guys opinions <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
Discussion Starter #7
anyone ? <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
Between the coolers listed (only the first 2 links worked) I would get the CNPS9500. But... you might want to look at some coolers that have more surface area (tower coolers).
Discussion Starter #9
the 3rd one is a Big typhoon thermaltake fan, the link doesnt work so i just re wrote it <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">
Discussion Starter #11
u 100% sure the zalman better dude? i hear people say the BT is better then zalman then zalman is better then BT, im kinda confused on which to get dude =S so its this fan right? <a href="http://umart.net/au/product_info.php?cPath=108_367&products_id=103877" target="_blank">http://umart.net/au/product_info.php...ucts_id=103877</a>
The 9500 is NOT better the the BT, the Scythe Infinity is though <img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick Out Tongue">
Discussion Starter #13
and how much is the sychthe infinity? i should get that if its better then BT and the zalman
Well I have the Big Typhoon right now and honestly it may be how I set it up but I hate it.<br />
<br />
For example (and im currently talking about this is another thread with some folks) MY ambient temp is 21c, someone elses is 28c yet he idles at the SAME temp as I do. So as far as I'm concerned the BT is overrated. BUT like I said I dont know nearly as much as these guys so I dunno.
Discussion Starter #15
whats average idle speed using a Typhoon Fan?? cuz atm im at about 31-33 idle with the normal standard cooling fan i got with the cpu<img src="/images/smilies/eek.gif" border="0" alt="" title="EEK!" class="inlineimg" />
Administrator
<b><u>Please stop bumping. Only bump every 24 hours</u></b> <br />
<br />
Well not including the easy installation of the CNPS9500 I would go for the BT as it will cool for you better. <br />
<br />
However you may notice your Idle temps dont drop..This is normal as its your load temps that are taken down.
Discussion Starter #18
roger, thanks for ur help enterprise <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
Paralysis through analysis....<br />
<br />
Maybe it's time to flip a coin. No offense. Both of the coolers are awesome. Temps depend upon a persons OC, ambient temp, airflow, case design and voltage. Since no two are the same, no two anwsers are going to be the same.<br />
<br />
Break it down: <br />
<br />
Copper = Good<br />
Larger surface area = better<br />
Larger Fan = better<br />
Higher CMF = better. BUT more dBA<br />
<br />
If you are concerned about a couple of C, then lap the HSF.<br />
<br />
Whichever you get, I hope that you enjoy it. <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
1 - 19 of 19 Posts
