Any tips on how to reduce my 8800 Ultra temps???
709 Views 18 Replies 11 Participants Last post by  ShaveWithALightsaber
hey, I live in the tropic s and its bloody hot here.
My Ultra is slightly overclocked and is running real hot. I have a lot of fans installed in my case and the GPU fan is at 100%, but load temps reach more 100C when running Crysis at peak.
I installed a PCI slot cooler right under my card and that brought the peak temps down to 90C, but now the slot fn is malfunctioning and the temps are back up.
think i should dump the Ultra and go for a GTX 285 or somethin??? will that be much cooler than an Ultra???
1 - 19 of 19 Posts
I would try to remove cooler and either get a better one or remount with better thermal paste. You could get another card but if your case doesn't have great airflow it will run hot too.
yeah i was thinking of getting an Arctic Cooling Accelero Xtreme 8800 but since its much thicker than the stock cooler its gonna block ALL of my SATA ports (currently Ultra is blocking 4 of 6 ports
also this dumps all the heat inside the case, which is gonna heat up the rest of the components eh?
AS5 would do totally fine.And is your cooler dual slot?My cooler is dual slot and pre volt-modded so i get pretty high clocks with my GT.
I have some MX-2, will that be better than the stock paste??
You should get the Accelero Xtreme for it. I got one for my 8800 GTX and it went from 87C at 600c/1566s/2000m down to 56C at 600c/1674s/2000m while folding. Ambient temps are at 22C and it now idles at 45C. When you have the fans at 100% you can hardly hear them if your case if closed.
get some MX-2 for the card. and try that. Another thing. it works like a charm but is ugly. is get a 80mm, or a 120m is even better and either mount it inside the case blowing right into the Ultra's Fan. or what gives the best temps for the air cooled graphics card. it's ugly, but it works. get the 120mm fan. and actually zip tie, or install it on the OUTSIDE of the case. on the back of the Tower. sucking air out. and position it directly over the exhaust vents on your Dual slot NV card. and have it suck air out. it gets the air moving fast through those cards and temps drop like crazy. it may be ugly, but who see's the back of the case, and it works better than you'd think.
You have a server case? Thats a problem right there...
its just a normal case, but huge, with wheels, about the size of a CoolerMaster ATCS 840
lots of fans but 80mm ones.
have you tryed useing the nvidia system tools and turning up the fan?
Just get an aftermarket cooler and use your MX-2. The AC Accelero is beast. I'm going to be getting it once it starts heating up in the summer.
ketchup is better then that stock stuff
really?
so i remove the stock heatsink and rub off the remaining TIM with some rubbing alcohol and apply the MX2, right?
How do i apply it exactly? put a small blob in the middle, or rub and even amout around the whole surface of the GPU and the RAM??
Easy fix, remove factory cooler, wipe off crap thermal paste, reapply better thermal paste, and go. I use Shin-Etsu and it dropped load temps by 20°C. Plus, I did not put ten pounds on there like they factory does.
by 20c cos of the new paste? wow.
should i use the rubbing alcohol to wipe off the paste on the RAM as well???
Your ram sinks should have thermal tape, do not touch that, just do the gpu proc.
Like h00chi3 said dont mess with the ram heatsink it will more the likly pull off some sticker and that would void the warrenty.
On the video card just changing the thermal past helps alot
So Iam gonna attempt this right now.
Just to recap.
remove the heastsink, clean the GPU TIM using rubbing alcohol on cloth, do not touch the RAM sinks or whateva, apply thermal paste on the GPU not the copper heatsink plate, rub it even with a polythene bag over my finger and put the heatsink back on?
Is this right?? Do I need to apply paste on the heatsink plate as well??
thanks guys.
1 - 19 of 19 Posts
