Originally Posted by busa so some bleach and peroxide....cool. Thanks guys. Now i'm off to the store for some chemicals... ![]() |
Originally Posted by fstfrddy another option would be to get an aquarium tubing brush and tie some fishing line to the handle and a sinker to the other end and pull the brush through the tubing. |
Originally Posted by pauldovi I cut up an old sock and tired it to some wire. Then I passed the wire through the tubing, and pulled the sock through. After a few passes, tube was crystal clear. |
Originally Posted by myComputerSucksMore() Make sure peroxide isnt very acidic, otherwize it WILL result in a chemical explosion! I know Bleach is a base, but be sure to make sure peroxide is not very acidic. For the post above, isnt it hydrochloric acid? |
Originally Posted by pbasil1 doesnt a base+acid just neutralize each other!? |
Originally Posted by DrDeville As Paul knows, I know little about chemistry. ![]() From my limited knowledge, I believe base+acid may indeed neutralize each other, it's just that "neutralization" may involve explosions, poisonous gasses, etc. For example, mixing chlorine (bleach) and ammonia is supposed to be a *very* bad idea. Poisonous gasses, I believe. ![]() ![]() |
