1 - 8 of 8 Posts
Beyond
I own the Asus Eee 1000HE netbook. I tried using setFSB to see if it could OC it at all. It froze pretty quick. The highest performance setting puts the CPU at 1.75GHz but I wanted to see if I could get more out of it. The problem could be the wrong clock generator (the one I used was for the 1000HD so it may not be the right one), RAM, or chipset. So any 1000HE owners have any luck OCing?
Beyond
Originally Posted by Asus Mobile View Post
If above link did not work well for you? Here is another.
Link.
Yep, that worked. The problem is it was made for the 1000H which has an Atom N270 1.6GHz 533MHz FSB (133x12). The 1000HE uses the Atom N280 1.66GHz 667MHz FSB (166x10). Because of the lower multiplier (10 vs 12) the CPU is underclocked instead of overclocked. I just need a little help modifying the .ini file to reflect the 1000HE spec changes.
Show the file? Have you resolved.
Beyond
Discussion Starter · #8 ·
No, I haven't worked on it more. I modified the file for the 1000H now it just has to be customized for the 1000HE. The figures don't really make sense so I'm not sure what to modify the FSB numbers to.
1 - 8 of 8 Posts
