Originally Posted by
xioros
Others have pointed most things out:
First, your case is NOT suited for high-TDP hardware, even with water cooling. This might work when you're using a blower-style GPU or if you split loops (120mm for the GPU & 240mm for the CPU) but don't take my word for it. GPU's are easier to pull heat from and GPU loops tend to be delta 20°, while CPU is preferred under delta 10°
A 5930K + 980 Ti on a single 360mm rad is very tight. You'll need a rad optimised for high-RPM fans, paided with 2K RPM+ radiator-suited fans, preferable in push/pull config.
You have some options:
- Swap the fans for high-RPM fans (although I doubt this will change a lot and will result in noise, a lot of it)
- Ditch the case for something that's actually suited for high TDP hardware.
- Use an extra external rad (Dual 360 for example)
- Remove the sidepanel
- Mod the case to allow for more airflow and a push-pull config (I don't think it fits without modding?)
- Split loops (although this won't improve the results too much)
- Lower overclocks
As for fans:
Everything above 2K get's loud, unless it uses a special blade design (like the GTs for example, and even those get audible above 2K). The 3K vardar will get loud.
EK lists the 2200 RPM at 33.5 dBA and
the 3000 RPM at 42 dBA. These ratings are bullcrap, but to give you an idea: dBA scale is logaritmic. Every 3 dBA doubles the "perceived sound level".
This is de vardar at 2200 RPM.
Some other things to note: When you're going exhaust-heat with the rad, you'll suck dust in the case. When you're going intake rad, you'll heat up the hardware in your case A LOT (Hard drives, SSD, motherboard, ... will all heat up easily above 50°
^Just my thoughts
