Anybody used this EK-SB MAX-EX chipset water block?
706 21
Hi guys and gals,
Does anyone own or have used this water block:
http://www.performance-pcs.com/catal...ducts_id=23494
I am planning to cool my chipset(my motherboard is a Maximus Extreme) with this block but I am not sure if it will interfere with my GPU(4870x2). Also, do you guys have any suggestion for the water blocks for my NB and Vregs?
I need something that will fit in my Maximus Extreme..Thanks a lot!!
1 - 20 of 22 Posts
· Premium Member
delete
Oops misread OP and thought you were asking about the Rampage Extreme -not the Maximus Extreme!
Originally Posted by javier
I wouldn't bother wc'ing your sb. They all stay cool and you're just setting yourself up for more hassles. There's a reason you see almost no one doing it...
If you insist on doing so, I'm no sure if this particular one will fit...
Thanks. The only reasong I am considering on water cooling the SB and the Crosslink chip is because I want to remove the Fusion block and the stock heatsink my board came in so I could have a better NB block w/ 1/2" OB barbs, because the fusion block is only 3/8" OD and the tubing that I bought was 7/16" ID..
Maybe I could just put some heatsink over my SB?
The SB/Crosslink water block I posted was I think made just for Maximus Extreme..
thanks!
Originally Posted by SpcCdr
delete
Thanks a lot for trying to help!!
Originally Posted by ChielScape
you could use the tubing ID-reducers supplied by ASUS... 3/8" doesnt hurt too much.
Okay.. I will look into it..Or maybe, do you think I could just put the 7/16" Id tubing on the 3/8" OD barb of the Fusion block and not have leaks?
I just though that I will affect the performance of my WC setup if I have all 7/16" ID tubing and have a 3/8"OD barb on the Fusion block.
Thanks!
Discussion Starter · #9 ·
Originally Posted by ChielScape View Post
well, i run 3/8" troughout my entire loop... i usually recommend that to anyone.
not sure if it would be very cost-efficient to change that now though...
yah, I agree with you since I just spent some money for my CPU only loop.
I think I misunderstood you, you said you usually recommend 3/8" barbs OD/ID or tubing OD/ID?
I am assuming that you are talking about 3/8" ID tubing right?
The Fusion block is a 3/8" OD barb but I dont know what is the ID.
Discussion Starter · #13 ·
you could try.. the difference is 1.6mm.. use VERY strong clamps.
Okay, will do!!..
Thanks!! My stuff should come in tomorrow so I will be able to start the setup soon
· Premium Member
7/16" ID will be really loose on 3/8" barbs, no way would I try that, I doubt you would ever get that clamped well enough that it wont leak.
If you have to neck down to 3/8" for that one block I'd just use 1/2x3/4" tubing on the whole thing. Then just get a foot or so of 3/8x1/2" tubing. Cut a little piece of it long enough to go over the 3/8" barb, then just slide you 1/2" ID tubing on over that and clamp it, that gives you a real good leak proof union without having to use reducers.
Or just use some reducers...1/2" barb to 3/8" barb Hose Adapter
· Banned
i guess you could try this with some thin-walled 1/4" tubing stretched over the 3/8" barbs... should work if you soften it with boiling water.
· Premium Member
Just use 1/2x3/4" tubing on the rig and 3/8x1/2" on the 3/8" will fit it just right, I've done it many times. No guess work involved..
Discussion Starter · #18 ·
I think that is a good idea but I already purchased my components and it will include a 7/16" ID by 5/8" OD masterkleer tubing.. I have some 3/8" ID tubing left over from my WC kit, so maybe I will use that and put the reducer that ChielScape recomended.
Thanks
Discussion Starter · #19 ·
I think I have some of those reducers laying around here at work, so maybe I will get some..
Thanks..
· Premium Member
Yeah $3 or $4 for some tubing is really expensive.
One thing about it, it would still be a lot cheaper then using 7/16" on 3/8" barbs and leaking all over his board.
1 - 20 of 22 Posts
