1 - 5 of 5 Posts
Hi I have an HP DM1-3000 and need an HDD cable... the DM1-3000 cables are nearly $20 and the DM1-4000 are less than $5...
They both look exactly the same... Just wondering if anyone knew for sure if it will work?
Thanks
Processed By eBay with ImageMagick, z1.1.0. ||B2
Originally Posted by chris89 View Post
Hi I have an HP DM1-3000 and need an HDD cable... the DM1-3000 cables are nearly $20 and the DM1-4000 are less than $10...
Thanks
Post links and pics of the both and I will look. To lazy to do anymore right now.,
Thank you for the page update.
They are both the same as in they have the same connectors.
The main difference is the cable layout. on the once connector the cable comes out on the back and the other comes out on the side... you need to see if that difference will still fit in your laptop will little to no modding at all on the chassis. but yes it will work.
Discussion Starter #4
Thanks man! I'll give it a shot and post back! After ordering of course.
Discussion Starter #5
Yeah it didn't work... Electrically it's different... won't work with hdd plugged in cant boot.
1 - 5 of 5 Posts
