1 - 15 of 15 Posts
hey as most know i have a.... problamatic 3000+winnie i am trying to get it to fx-55 core speed even though it will be eworth only a fx-53 any way i can have it stable at 297X8.5 2.525mhz but if i try to raise my htt/fsb it starts not wanting to boot windows also i have a nother problem i cant use the 133or125 divider on my mobo at anything over 285 so to get to above 2.6ghz i either have to overclock my ram which is only good to 211 at the 140divider or underclock at the 100divider anyway i would like it if i could get some help it will post at up to 3600mhz but it definintly will not boot windows my specs are as follows
AMD athlon 3000+
winchester core
939
model 1f
stepping 0
revision DH-DO
ram 1024mb geil value
l1 i-cache64kb
l1 d-cache64kb
l2 cache512kb
please help me! i really would like to get to 2.6stable
load temps are 44c
idle 26
vcore is at 1.73 now current speed is 295X8.5=2507 39.32%overclock
Discussion Starter #5
ill list genie bios will be back in 10 minutes
all i know about the divider problem is that they stop working at the 285mark at 8.5multi
Discussion Starter #6
heres the genie settings
fsb 295
ldt 3.0
ldtbus up19 down16
cpu/fsb x8.5
pci/ex100mhz
cool+quiet disabled
startup vid startup
vcore 1.475
cpu/vid above normal *123%
ldt vcore1.30
chipset vcore 1.60
ram 2.7
ram+.03 enabled
dram
auto
tcl 2.5
trcd 4
tras8
trp 4
trc auto
trfc auto
02
02
02
03
3120
auto
enabled
auto
0
auto
auto
auto
normal
auto
250 cycles
disable
16X
07X
disable 4 bursts
Best to avoid the .5x
Have you under clocked the CPU to find the RAMs max stable speed and ...
Then set a stiff divider on the RAM to find the CPU's max stable speed yet?
Once you do try http://math.gogar.com/athlon64.cgi and see what those factors bring up. Note the last colume "lower is better" which relates to over all effency.
Vcore should be at around 1.65 tops, you wont get much more overclock by going over that and by going over that the chances of it spontainiously dying are greatly increased. Try running at 288 X 9 with ram divider at 140 (7/10)
Or if you think you can squeeze 216 out of your ram you could run at 150 (3/4) divider. Try upping your Vdimm (Ram Voltage) as that mingt increace the OCing ability of your ram.
As always, start off at a frequency you know your system can run at and go from there. Also keep in mind this may be all you can get from your proc.
You sure about that?
What bios are you running? Try 704-2bta...said to be the best overall bios for most configurations...
If you are on vapo, you should be able to get 2.6, it might just require alot of volts.
The Vapochill Micro is a heatsink
shows how much I know, lolz
Then dont expect to get 2.6, you are at your chips limit. 2.5 is an excellent overclock anyways for a winnie
Originally Posted by metalkobra
Well i see the problem, 290mhz+ you need to be on 2.0 LDT multi kthx bye!
wrong......3.0 LDT multi kthx bye!
1 - 15 of 15 Posts
