1 - 20 of 28 Posts
What are your fps? I'm getting 50ish average, but in tranquillen (blood elf), they dip to like 40ish and when I turn left or right, it's pretty noticeable....
I'm running crossfire 4890's with vsync on, what do you guys get??
Is WoW SLI or Crossfire aware yet? I'm not sure it is you know...
Warcraft is very CPU heavy still, but 3.7GHz should be enough to keep up... I'm not sure where your slowdowns are coming from, but try putting some more anti-aliasing on?
Sometimes it's server based, other times it's network lag, and other times it's because it has to load a whole pile of models and textures in short order.
A great way to speed up WoW play is to put the install on an SSD.
I run >60fps everywhere with everything turned all the way up at 19x12 and -dx11 added to the command string. Before the addition, I would sometimes dip into the 50s in Org if it was SUPER busy.
I did get a minor performance boost mirroring my drive though.
How do I add the DX11!!!!! I have been searching this. I can't figure out where to add the -d3d11 or -dx11. I can;t just add it to the end of the filename can I?
Originally Posted by Chupacabras;11994283
WoW is not coded for multi card setups..
If I enable crossfire on my pc everything looks blurred at medium distance, with crossfire disabled, I run 60 fps in Org on ultra everything, max af, 1920x1080..
i get 100% usage out of my 3 5770's according to afterburner. before cata they didn't go over 60% usage. i also play with ultra settings at 1920x1080 and never dip below 30fps in cities, the rest of the time its between 70-120fps.
With my sigrig, I run at 60 fps steady, Ultra, except shadows. I used to have some problems with dips, back before i OC'ed to 4 GHz, and it seemed it was due to Speedstep. I can't remember where I read it, but disabling speedstep helped me, at least.
Either add the dx11 tag, and/or change "shadows" to low / off and you'll see an increase in fps.
I get a constant 60fps with vsync on no matter what I'm doing. I believe I'm running Ultra with just shadows turned down / low.
Follow the steps here to get DX11 in WoW:
Expand a shortcut to the WoW.exe with "-d3d11". Alternatively, open the "Config.W T F" in "\World of Warcraft\W T F" and add the line SET gxApi "d3d11" (with quotes)
DX11 in WoW is mainly for performance enhancements (I gained a good 30 fps or so on my GTX 480 before I stuck Vsync on), although there are a few graphical enhancements too, including full world reflectivity on water.
I haven't run it without Vysnc for a while (keeps my GPU usage low, therefore thermals and acoustics stay low), but I'd usually get over 100fps if I remember correctly, except for busy cities. I get a constant 60fps now though.
1 - 20 of 28 Posts
