Definitely don't go with sleeve bearings.
How quiet are we talking? Single-digit db?
Originally Posted by crashnburn_819 ![]() Definitely don't go with sleeve bearings. How quiet are we talking? Single-digit db? |
Originally Posted by doat ![]() something below 35DBA would be good my yate loons are 40DBa and that is loud, i want something that moves at least 80CFM. I am liking these silverstone fans http://www.newegg.com/Product/Produc...82E16811999344 and i have a silverstone fan controller with an extra spot open for another fan to control. |
Originally Posted by spaceballsrules ![]() You want Scythe S-Flex fans. 75 CFM/ 35 DBa - http://www.newegg.com/Product/Produc...82E16835185065 64 CFM/ 28 DBa - http://www.newegg.com/Product/Produc...82E16835185006 49 CFM/ 20 DBa - http://www.newegg.com/Product/Produc...82E16835185005 |
Originally Posted by Aiyo ![]() go with the update FM123s http://www.newegg.com/Product/Produc...82E16835220022 |
The Silverstone 'Debacle' I have tested both the aforementioned FN122 and FM123 for Round 2 and have not listed their performance. I hate them with a passion. Neither are anywhere near their CFM ratings and the FM123 is more annoying to listen to than the 220CFM Deltas in Round 1. I'd go as far as saying it's more annoying than a crying baby. Unlike the baby though, you can kick it. At this point, the FM121, FM122, FM123, and FN122 have ranked among the most annoying or worst performing fans I have ever tested/used. They may all be lemons, but if the lemon rate coming out of Silverstone is 80%, you should stay away. If they are good representations, you should stay away. So ultimately, based on my experience with them, you should stay away. And I really don't have a bias...I actually like the FN121 quite a bit. Shame it has ******ed siblings. I wanted to exclude all Silverstones from this test, but because I was using an FN121 as a carry-over all-star comparison from Round 1, that was not possible. It actually did fairly well in this round-up as well. Go figure. |
Originally Posted by Marin ![]() http://www.xtremesystems.org/forums/...d.php?t=170224 |
Originally Posted by gnolnats ![]() Check out the specs on the Twister. I have several of these and they're great. You can remove the blades for cleaning and they have magnetic bearings for long life. http://www.newegg.com/Product/Produc...82E16835214001 |
