Well I bought some 1/2" ID 5/8" OD compression fittings and I was planning on using Tygon tubing for my loop, but now I feel like I want my tubing to look a little better so I decided to go with blue tubing.
The problem is that, there aren't many options on blue 1/2" ID 5/8" OD.
Here is the only thing that I was able to find
http://www.mountainmods.com/flexible...-od-p-455.html
Have any of you tried this? Do you know if it is any good?
Thanks.
Thanks.
