1 - 10 of 10 Posts
That's what I figured. I cross referenced the specs and they seemed identical otherwise.
Kind of pointless that they did this but I'll likely go with the one with the less restrictive front grills.
Originally Posted by clark_b
I thought the PC-7 cases were bigger than the PC-60's??
No they are the same size.
http://www.dvhardware.net/article37612.html
The difference between the PC-7FN and PC-60FN is the front panel design. The PC-7FN has smooth rounded vent holes, while the PC-60FN has a more open bezel front face. Each caters for a unique different taste.
Yup, just the front. Got the PC-60FNW for the wife's rig.
Regarding part numbers, the W = side panel window and the X = black inside.
1 - 10 of 10 Posts
